Hi all,
I just have a couple of questions RE RMS connectivity.
I have a trb245 and the connection to the RMS is very sporadic for example it will drop connection to the RMS for upwards of 6 hours at a time, power cycling fixes the issue for a short amount of time.
I suspect the issue is caused by my isp assigning a new IP address to the device.
My question is this:
Could that be the cause of the dropping? and must I have a public IP or can I use a private static IP address?
My needs are Serial connection and data to server - sending MQTT data to a third party.
And device monitoring with the RMS service.
Any details you need please reach out,
Thanks in advance.
J dev
