(RMS) API Permissions scopes per endpoint
Hi!
In the API reference for RMS, it would be nice to have documented what minimum required permissions are needed on the caller’s API credentials for each endpoint.
It isn’t obvious for an endpoint like assign tags, what scopes are needed. device:read and device:write isn’t enough it seems, also tried adding tags:read.
Currently, documents created for RMS API is about reading Credit Codes and Generating Remote Access Links. For scopes, can you try to include tags:write as well similar to the image below.
Let me know the results!
