RMS alert notification
Good morning,
I’m trying the RMS software and, just to test, I initially enabled an alert (from device-Management
Actions-Configuration-
Alerts & automations menu) to report mobile data disconnection. Now, although I have eliminated the alert, I continue to receive a notification text message every day. It wouldn’t be a big problem except that I have to pay for the text messages and I really don’t need the notification. How can I solve it? Thank you
Thank you for contacting us. Could you kindly utilize the command-line interface (CLI) and share the output for the following command?
cat /etc/config/events_reporting
Thanks,
Mahmoud
Hi Mahmoud,
I obtain the following answer: Cat: not found
Could you please try it again and ensure that all alphabets are in lowercase?
Thanks,
I’m sorry, this is the output:
config rule
option enable ‘1’
option event ‘Mobile Data’
option eventMark ‘data disconnected’
option message ‘Router name - %rn; Event type - %et; Event text - %ex; Time stamp - %ts;’
option telnum ‘+39**************’
option action ‘sendSMS’
option recipient_format ‘single’
Thank you for providing clarification on the output.
Kindly access the CLI and execute the following command:
vi /etc/config/events_reporting
Clear the current content by pressing the d key.
After clearing the content with the d key, press the ESC key, and then type :wq to save and exit.
Verify whether the content has been removed by checking again.
Thanks,
It works. Thank you very much
