i am using the device fmc130, the device read the rfid card , but does not working the immovilizer,When the ignition is detected, it activates the output to stop the engine, but the output does not change state when it detects the authorized card.
Hello @Edgarpacheco25,
I hope you are doing well. Could you try to check if the RFID card were getting recognized on the iButton parameter from the I/O tab?
If not, I recommend you to check on the wirings of the RFID reader with the device otherwise it could be a list of Authorized RFID were added on Authorization ID List.
Patrick S.
