Hello Everyone
I need help
Is it possible to set a modem reboot when the signal drops below a certain value in the rut240?
Thank you
Hello Everyone
I need help
Thank you
Good afternoon,
It is possible to configure the Teltonika RUT240 router to reboot automatically when the signal drops or when connectivity issues occur, but not directly by signal strength threshold. Instead, the device supports an Auto Reboot feature that can trigger a reboot based on network connectivity checks, such as failed ping or wget requests to a specified host.
Use the Ping/Wget Reboot feature in the Auto Reboot section. The router periodically sends ICMP ping or wget requests to a specified IP address or URL.
Arturas
Thanks for the reply
I already use the ping reboot function, but it doesn’t work because even with a low signal the ping manages to pass and therefore the modem doesn’t reboot
As above mentioned, such function does not exist, only a similiar workaround.
Arturas
