Replaced RUT950 RMS credit gone
I had to replace a RUT950 in RMS but now i lost the credit, is there a way i can get my credit back ? i had a 5 year subscription on it
From what you’ve described, it sounds like you had a management pack assigned to the device, rather than a credit. Packs should stay tied to the device information (such as serial number, IMEI etc.).
Could you confirm that the RUT950 that you’ve replaced is a different device other than the one that had the pack assigned to it?
J.
Yes correct i have a management pack, the RUT950 broke so i replaced it with a new one
I’ve sent a form to you privately, since additional sensitive information is required to assist you further. Once you’ve filled the form out, I’ll reach out to you.
In the ticket ID field, simply enter the ID for this thread, which is 12747
J.
