Repeater and Antenna
Hi i just installes my RUT850 in a flat and i would like to extend my incoming and outgoing signalstrength. Can you:
A) recomand a good working antenna and
B) how can i connect a repeater for the RUT 850?
Thanks a lot for any ideas. Best Olaf
Before replacing the antennas, we recommend checking your mobile signal in the router’s WebUI. Go to Status → Network → Mobile and compare the readings with our mobile signal strength guide
If reception is poor, you can consider a third-party antenna. The RUT850 has two FAKRA-D mobile antenna ports, and we don’t currently offer a FAKRA antenna for this setup. Look for an antenna that covers your operator’s LTE bands and has two leads with compatible FAKRA-D connectors.
To extend Wi-Fi coverage in your flat, choose a 2.4 GHz Wi-Fi extender with wireless repeater mode, since the RUT850 has no Ethernet ports. During setup, select the RUT850’s Wi-Fi network and enter its password. Place the extender partway toward the room you want to reach, where it can still pick up a strong signal from the router.
T.
