Trying to get rid of the HTTPS security warning on my RUTX50 and this guide does’t seem to be current anymore? The files import is failing (invalid file names). Also, what is the best practice when using a DDNS service (No-IP).
Yes the guide is depreciated and does not work anymore, but you can try to remove it using Let’s Encrypt certificate, which from 7.8 version you can generate on the router itself, here you can find more information about that in the official Teltonika Networks youtube channel: https://www.youtube.com/watch?v=hKIyeuZ0t1U
So try to generate Let’s Encrypt certificate via router and then uploading it, to remove the Https warning.
