We’ve got a site where we were planning to use the Remote Access relay to access a number of HTTP/S interfaces within the network, however we’re only having success to half the devices. One rejects immediately with the Teltonika problem occurred screen, the other loads forever. Starlink router webpage via HTTP and Raspberry Pi via SSH work fine though.
At the moment, it is difficult to determine the exact cause of the issue. To help us investigate further, could you please clarify a few details?
Could you verify that the RMS Remote Access entry is configured with the correct protocol and target port used by the end device?
For the devices where the connection is rejected immediately, is the Teltonika device configured as the default gateway for those end devices?
What types of devices are you trying to access remotely? Additionally, which devices are affected by the issue (those that cannot be accessed or take a long time to load)?
As an additional troubleshooting step, have you tried creating an RMS VPN Hub connection to the end devices to verify whether they can be accessed through the VPN service instead? For more information on configuring an RMS VPN Hub, please refer to the following Wiki article:
Your answers will help us better understand the issue and continue troubleshooting.
We appreciate your patience and look forward to your response.
