Regarding EOIP problem adding to CLI
Hello
We are trying to configure EOIP with L2TP in Router RUT951 and we arfe facing problem adding rule,
uci add eoip eoip , not found as a command
What should we do ?
Thank you
EoIP is not available currently. However, there are plans to add it in the future. If this feature is absolutely necessary for your scenario, you can try contacting your designated sales manager to potentially obtain test firmware with EoIP support. However, I cannot guarantee that this will be available. The other two options are:
  • Wait for the official firmware with EoIP support.
  • Add functionality yourself using our SDK here. However, you will have to develop this on your own, as custom developments are outside the scope of our technical assistance.
