Hello everyone!
I am trying to write a simple script that scans rs485 incoming data. Data are periodic messages of raw hex bytes, fixed length, with a specific end byte. I can view the data on PC using Docklight, messages are ok. But I cannot with the incoming messages on the TRB246 cli.
A simple cat < /dev/rs485 does not show anything.
microcom /dev/rs485 -s 9600 permitts to send data from TRB246 to PC. But does not display any simulated data sent by PC with Docklight (ASCII or HEX format).
echo “hello” > /dev/rs485 shows “hello” on Docklight (on PC)
I tried to configure rs485 device with WebUI ‘Over IP’ section, does not help. I tried to disable everything dealing with rs485 on Webui, does not help.
setup:
Please, do you know how to display rs485 incoming raw data?
Thank you in advance!
