Read Temperature Sensor / Log?
I would like to operate my RUTX50 inside a Poynting EPNT-4 antenna. The router is integrated into the antenna housing.
Is there an option to read the temperature sensor (if available) from my RUTX50 via CLI or similar methods?
Moritz
Thank you for your inquiry.
If I understood correctly, you’re referring to reading the internal temperature of the RUTX50? If so, the router’s modem temperature can be accessed using the following commands via CLI:
  • gsmctl -c
  • ubus call gsm.modem0 get_temperature
Please let me know if you have additional questions or need further assistance.
Hello, perfect, thank you very much. One more question: Can the temperature be transmitted to a broker via MQTT?
Yes, the temperature can be transmitted to a broker via MQTT. There are several ways to achieve this:
  1. Monitoring via MQTT: This is a straightforward method to monitor and transmit data via MQTT. Detailed instructions are available in our wiki page here.
  2. Modbus MQTT Gateway: You can use the Modbus MQTT gateway functionality. A comprehensive configuration example can be found here. For the RUTX50, system temperature data is stored at: register number – 6, number of registers – 2.
Let me know if you have any additional questions or need further assistance.
Best regards!
