Random default password
Hi
Is there a way to check what the random password is via the GUI? I know it is printed on a sticker on the bottom of the device but this is quite difficult to access. Device = RUT10
If you’re referring to the default password, I’m not sure it will be possible, since there’s pop-up prompt to change the default password of the device upon logging in the WebUI for the first time (or after factory reset).
Maybe someone from Teltonika can help if it’s possible to disable the prompt via CLI.
Not possible.
Sticker only.
Thanks for reaching out!
Unfortunately there is no other method to see the default password. Due to regulations regarding the personal data protection’s all the random generated password are deleted from our database after some time!
So you should check the password sticker under your device.
Caner
