is there a way to change the update frequency of the RUTX14 from the current one position per second (1Hz) to 5Hz?
Possibly through AT commands on ttyUSB0?
Best regards…Christian
According to Quectel’s hardware design reference sheets for the EG12 modem series, which is used in RUTX14 devices, the modem outputs NMEA sentences at a fixed data update rate of 1Hz. I couldn’t find any AT commands that would enable changing the update frequency on this modem.
Thanks for the fast reply!
