Hello there am trying to configure for proximity it shows I have to enable this features through Bluetooth features .But the configurator am using does not have that option.
I need your support on this
Hello!
The message to enable proximity sensing through “Bluetooth features” in a configurator that lacks this option suggests the proximity feature might not use Bluetooth or the current configurator is incorrect. To help, please specify the device/app you’re configuring, the configurator you’re using, and where you see the Bluetooth message. The proximity setting might be elsewhere (Wi-Fi, general device settings) or require a different configuration method or app from the manufacturer.
The configurator am using is 7.0.47
Firmware(FW): 55.02.03 rev05
The device: GH5200
Hello @Isack.Shilla,
I hope you are doing well. You may refer to the link mentioned below to access the GH5200 Proximity Firmware version.
GH5200 Proximity: https://wiki.teltonika-gps.com/view/GH5200_Stable_firmware#Stable_Proximity_firmware
Additionally, you may refer to this Wiki Page to further understand the Proximity Feature: https://wiki.teltonika-gps.com/view/Proximity
I hope this helps.
Patrick
