Properties IO data FMC650
I would like to know if there are any properties in the IO data that can help identify the device model, such as whether it is an FMC650, FM6320, or another device.
Thank you for your response.
Blockquote
Khaled BRIBRI
Hello @khaled.Bri
It’s not possible to get hardware details in I/O ,
Meanwhile, the command allver will responds with information about hardware
Please check link for details FMB allver - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
The reason I’m asking is that IO112 is no longer available for the FMC650 model, but it is still supported for the FM6320 model. I am looking for a solution to continue using IO112 with the older FM6320 model while skipping it for the newer FMC650 model.
