Probleme de connection
Bonjour, mon routeur Teltonika fonctionnait bien en Wi-Fi avec un contrôle d’accès à distance, puis, suite à la mise à jour du dernier firmware il y a 3 jours, j’ai perdu la connexion Wi-Fi au routeur et il est impossible de le reconnecter. Que dois-je faire ? C’est assez urgent. Merci.
So that people can help you further, a few questions.
Which Teltonika router are you using?
What firmware versions have you got, you may have two firmwares, the first for the device and the second for the modem?
Greetings
Thank you for contacting us.
As previously requested by @akwe-xavante, could you please confirm your router’s model and the installed firmware version?
To assist us in investigating further, please also confirm:
  • Whether the Wi-Fi network remains visible and whether an error message appears when attempting to connect.
  • Whether you can access the router’s WebUI through an Ethernet connection.
These details will help us determine the appropriate next steps.
T.
