Problem with Version branding
Hi. We have problem with update with save changes after branding firmware version on trb 145. If change version with menuconfig, version of firmware not changes. If change version via file “gpl_version”, firmware version changes but when update firmware don’t saving settings (version is older than current)
Could you clarify the issue? If you are installing older firmware than the current one, then Keep Settings will not work, as that could introduce configuration file compatibility and other issues. Downgrading should only be done without Keep Settings enabled.
I have also sent you a form to fill out - in the Description section, please add the serial number of your device that you are testing on. I would like to check if there were any hardware changes that could introduce compatibility issues.
In the ticket ID field please enter 5112. Thanks!
