Problem with RUT200 firmware update
Good morning,
I’m contacting you for a problem with my RUT200.
After each firmware update higher than RUT2M_R_00.07.12.3_WEBUI.bin, the configuration previously made with the “relay configuration pacage” no longer works and I can no longer reach the PLC connected to the WAN port of the RUT200 router.
So, i have to downgrade the firmware to return to 07.12.3.
Have you encountered other problems of this kind with other RUT modules? By chance I noticed that the “Topology” button has disappeared in the menu, could that be a problem?
Thanks.
The problem remained even with the latest firmware released, precisely 7.13.3.
After the update I lose “the bridge” between WAN and WiFi and I can’t reach the connected node.
I have to downgrade to the latest working version which is 7.12.3.
Apologies for the delay. To clarify, starting from RutOS 7.13 and later, the Relay configuration package on the RUT200 was moved to the Package Manager. To continue using it as before, you’ll need to install it manually via System → Package Manager by searching for Relay configuration and installing the package from there.
Once installed, your previous configuration approach should work as expected on the newer firmware versions.
