Sun Oct 1 07:12:14 2023 daemon.info dnsmasq-dhcp[3565]: read /etc/ethers - 0 addresses
Sun Oct 1 07:12:14 2023 daemon.notice netifd: mob1s1a1 (15003): Request timed out
Sun Oct 1 07:12:14 2023 daemon.notice netifd: mob1s1a1 (15003): “Unknown error”
Sun Oct 1 07:12:14 2023 user.notice mobile.sh: Received unknown error(1/5): “Unknown error”
Sun Oct 1 07:12:14 2023 daemon.notice netifd: mob1s1a1 (15003): Releasing client-id 14 on /dev/cdc-wdm0
Sun Oct 1 07:12:14 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Sun Oct 1 07:12:15 2023 kern.info Mobile data disconnected (internal modem)
Sun Oct 1 07:12:15 2023 daemon.info dnsmasq[3565]: read /etc/hosts - 4 addresses
Sun Oct 1 07:12:15 2023 daemon.info dnsmasq[3565]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Oct 1 07:12:15 2023 daemon.info dnsmasq-dhcp[3565]: read /etc/ethers - 0 addresses
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (15003): Command failed: Not found
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (15003): Command failed: Permission
Sun Oct 1 06:15:13 2023 daemon.info hostapd: wlan0: STA 08:3a:8d:8b:91:f4 IEEE 802.11: disconnected due to excessive missing ACKs
Sun Oct 1 06:55:36 2023 daemon.notice netifd: mob1s1a1_4 (15601): udhcpc: broadcasting renew
Sun Oct 1 06:55:37 2023 daemon.notice netifd: mob1s1a1_4 (15601): udhcpc: lease of 10.209.175.8 obtained from 10.209.175.9, lease time 7200
Sun Oct 1 07:11:56 2023 user.info mwan3track[3041]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Oct 1 07:11:58 2023 user.info mwan3track[3041]: Check (ping) failed for target “8.8.8.8” on interface mob1s1a1 (qmimux0). Current score: 6
Sun Oct 1 07:11:58 2023 user.notice mwan3track[3041]: Interface mob1s1a1 (qmimux0) is disconnecting
Sun Oct 1 07:12:05 2023 user.info mwan3track[3041]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 5
Sun Oct 1 07:12:07 2023 user.info mwan3track[3041]: Check (ping) failed for target “8.8.8.8” on interface mob1s1a1 (qmimux0). Current score: 5
Sun Oct 1 07:12:09 2023 daemon.info gsmd[1644]: [check_req_timeout:104] error: [MODEM_MANAGER] Warning: request reached timeout (11s) on 2-1 [2c7c:0800] modem!
Sun Oct 1 07:12:11 2023 daemon.notice netifd: mob1s1a1 (15578): Request timed out
Sun Oct 1 07:12:11 2023 daemon.notice netifd: mob1s1a1 (15578): Mobile connection lost!
Sun Oct 1 07:12:11 2023 daemon.notice netifd: Interface ‘mob1s1a1’ has lost the connection
Sun Oct 1 07:12:11 2023 daemon.notice netifd: Network device ‘wwan0’ link is down
Sun Oct 1 07:12:11 2023 daemon.notice netifd: mob1s1a1 (15003): Stopping network mob1s1a1
Sun Oct 1 07:12:11 2023 daemon.notice netifd: Network device ‘qmimux0’ link is down
Sun Oct 1 07:12:11 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Sun Oct 1 07:12:11 2023 daemon.notice netifd: mob1s1a1_4 (15601): udhcpc: SIOCGIFINDEX: No such device
Sun Oct 1 07:12:11 2023 daemon.notice netifd: mob1s1a1_4 (15601): udhcpc: received SIGTERM
Sun Oct 1 07:12:11 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Sun Oct 1 07:12:11 2023 user.notice mwan3-hotplug[14999]: Execute ifdown event on interface mob1s1a1 (unknown)
Sun Oct 1 07:12:11 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Sun Oct 1 07:12:11 2023 user.info mwan3track[3041]: Detect ifdown event on interface mob1s1a1 (qmimux0)
Sun Oct 1 07:12:11 2023 user.info mwan3track[3041]: Check (ping) failed for target “1.1.1.1” on interface mob1s1a1 (qmimux0). Current score: 4
Sun Oct 1 07:12:12 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Sun Oct 1 07:12:12 2023 daemon.warn dnsmasq[3565]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Oct 1 07:12:12 2023 daemon.notice netifd: mob1s1a1 (15003): Stopping network on /dev/cdc-wdm0!
Sun Oct 1 07:12:12 2023 user.info mwan3track[3041]: Check (ping) failed for target “8.8.8.8” on interface mob1s1a1 (qmimux0). Current score: 4
Sun Oct 1 07:12:12 2023 user.notice mwan3track[3041]: Interface mob1s1a1 (qmimux0) is offline
Sun Oct 1 07:12:12 2023 user.notice mwan3-hotplug[15268]: Execute disconnected event on interface mob1s1a1 (qmimux0)
Sun Oct 1 07:12:12 2023 kern.info WAN (mob1s1a1) is down, no more backups to switch
Sun Oct 1 07:12:14 2023 daemon.info dnsmasq[3565]: read /etc/hosts - 4 addresses
Sun Oct 1 07:12:14 2023 daemon.info dnsmasq[3565]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (15003): Command failed: Permission denied
Sun Oct 1 07:12:15 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Sun Oct 1 07:12:15 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): wwan[16262] Using wwan usb device on bus 2-1
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): wwan[16262] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): Failed to parse message data
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): Command failed: Not found
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): WARNING: Variable ‘list’ does not exist or is not an array/object
Sun Oct 1 07:12:15 2023 daemon.notice netifd: mob1s1a1 (16262): Creating context with PDP: 1
Sun Oct 1 07:12:15 2023 user.notice mwan3track[3041]: Interface mob1s1a1 (qmimux0) is offline
Sun Oct 1 07:12:16 2023 user.notice mwan3-hotplug[16422]: Execute disconnected event on interface mob1s1a1 (qmimux0)
Sun Oct 1 07:12:18 2023 daemon.notice netifd: mob1s1a1 (16262): Starting network mob1s1a1 using APN: internet.telekom
Sun Oct 1 07:12:18 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --username telekom --password telekom --auth-type pap --apn internet.telekom --pdp-type ip
Sun Oct 1 07:12:49 2023 daemon.notice netifd: mob1s1a1 (16262): Network registration failed
Sun Oct 1 07:12:49 2023 daemon.notice netifd: mob1s1a1 (17764): Stopping network mob1s1a1
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17764): Command failed: Not found
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17764): Command failed: Permission denied
Sun Oct 1 07:12:50 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Sun Oct 1 07:12:50 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17842): wwan[17842] Using wwan usb device on bus 2-1
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17842): wwan[17842] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17842): Quering active sim position
Sun Oct 1 07:12:50 2023 daemon.notice netifd: mob1s1a1 (17842): Calculated qmimux ifname: qmimux0
Sun Oct 1 07:12:51 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Sun Oct 1 07:12:51 2023 daemon.notice netifd: mob1s1a1 (17842): Starting network mob1s1a1 using APN: internet.telekom
Sun Oct 1 07:12:51 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --username telekom --password telekom --auth-type pap --apn internet.telekom --pdp-type ip
GOING BACK UP
Sun Oct 1 07:16:14 2023 daemon.notice netifd: mob1s1a1 (24607): Starting network mob1s1a1 using APN:
Sun Oct 1 07:16:14 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --pdp-type ip
Sun Oct 1 07:16:15 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): 14
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): cid4: 14
Sun Oct 1 07:16:15 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Sun Oct 1 07:16:15 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,14
Sun Oct 1 07:16:15 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --start-network --profile 1 --auth-type none --username --password
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): pdh4: 1498348848
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): 1498348848
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): Setting up qmimux0
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): Setting MTU: 1500 on qmimux0
Sun Oct 1 07:16:15 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Sun Oct 1 07:16:15 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Sun Oct 1 07:16:15 2023 daemon.notice netifd: mob1s1a1 (24607): Setting up qmimux0 V4 DCHP
Sun Oct 1 07:16:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Sun Oct 1 07:16:15 2023 daemon.notice netifd: Network device ‘qmimux0’ link is up
Sun Oct 1 07:16:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
What can i do ?
