When setting back a backup to set up the port forwarding on FW 00.07.04.3 i have no issues. when i set back the same backup on 00.07.12 it doesn’t work.
Are there any settings added to the new FW that i need to set for the port forwarding to work ?
I’ve compared the other settings between both versions. The available settings are equal.
There should be no issues with port forwarding on the latest firmware. The most recent version available is 7.12.3, which can be downloaded here: RUT241 Firmware Downloads.
