Hi, I was trying to read thru documentation, but I am not sure what is the best approach. We have some production lines that have same IP range and I need to communicate with PLCs accross the lines.
So I buy 2 pieces of RUTX10 for test and start to play. I am surprised, as SW and HW part of Teltonika seems pretty well for me for that price!
Now what is your recommendation? We need access PLCs by their virtual IP address on WAN side. For example there will be 192.168.10.10 as router WAN ip and also 192.168.10.11 IP alias for PLC(on WAN side).
PLC have in reality address 192.168.0.1 . I tested this RUTX 1-to-1 NAT - Teltonika Networks Wiki , but it seems not working in my case. Should I try port forwarding instead? Can it be used with VIP on WAN side? Maybe there is another, better, solution Thanks
