Poor performance
Purchased Rut 951 for my Motorhome to obtain better internet connectivity when in remote locations. Found my iPhone is performing better. I upgraded my antennae from Poynting Puk 3 to a Poynting Mimo 5 to improve the situation and find my iPhone is still outperforming this equipment with 5x download speeds. Totally disappointed with equipment. Can you advise/assist please?
So you comparing CAT4 module with your iphone’s CAT20?
Surprised that the routers being sold are so far behind. Whilst I knew I wasn’t buying the most expensive model I did expect when it was connected to an external antennae to perform better. I should have done my homework better
With the better antenna you should win some stability in your case, but maximum speeds will be limited by module’s LTE category as @hrtx mentioned
