OVPN import on older devices
Hi all
I have a RUT850 with FW ver.: RUT850_R_00.01.04.
How do I import an OVPN file from my Firewalla firewall at home ?
At least I cannot follow the guide at Configuration file .ovpn upload tutorial - Teltonika Networks Wiki (teltonika-networks.com)
THanks from Jakob
The RUT850 router reached its end of support two years ago. I recommend upgrading to a newer router for better security and performance.
However, you should still be able to upload a .ovpn file by following these steps:
  1. Go to ServicesVPNOpenVPN.
  2. Check the “Enable OpenVPN config from file” box.
Please note that this option might be unavailable due to outdated firmware. If this happens, you will need to set up the client configuration manually.
Thats exactly the topic - no option to import the ovpn config.
WHich product is the 850 replacement ?
Or which product supports Wireguard VPN ?
The RUT850 was a Wi-Fi-only router, so there isn’t a direct replacement model. If you need a mobile connection and 2.4GHz Wi-Fi, you can consider the RUT241 (Cat4) or the RUT260 (Cat6) for better speeds. If you need 5GHz Wi-Fi, look into the RUTX series devices. You can find all our wireless-supported routers here: Teltonika Networks Wireless Routers.
All our current routers (not in EOL) support WireGuard VPN.
