Mobile broadband is used as primary WAN connection for a Unifi Dream Machine Pro. A Huawei H155-383 in bridge mode delivers a stable WAN connection.
An OTD500 was bought to allow for outdoor installation. However I have not been able to setup the OTD500 to deliver WAN to the UDM Pro.
The OTD was setup in bridge mode,
the UDM Pro’s MAC address was added in “General settings”
Delegate IPv6 prefixes is turned “on”
The firewall settings are “unspecified”
As stated above - the Huawei router works reliably in bridge mode. Is it possible to replace the Huawei router with the OTD500, or have I bought the wrong product?
In this case, to assist and troubleshoot your issue effectively, we’ll need to continue this process privately, because sensitive/publicly unshareable information, such as the troubleshoot file, public IP addresses, serial numbers, etc., needs to be gathered.
You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 15253 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
