I have a RUT241 that we want to use as a OpenVPN client. I tried to connect it to our server, but without succes.
For what i can see the problem is in the tls-crypt-v2 key, can you confirm that the RUT241 is not supporting tls-crypt-v2?
This is how the .ovpn-file looks like:
client
dev tun
proto udp
tun-mtu 1371
mssfix 0
remote 1194
resolv-retry infinite
remote-cert-tls server
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
auth-nocache
cipher AES-256-GCM
auth SHA256
-----BEGIN CERTIFICATE-----
Data removed
-----END CERTIFICATE-----
Data removed
-----BEGIN RSA PRIVATE KEY-----
MData removed
-----END RSA PRIVATE KEY-----
-----BEGIN OpenVPN tls-crypt-v2 client key-----
Data removed
-----END OpenVPN tls-crypt-v2 client key-----
In my log output i can see these errors:
2505 Thu Mar 20 23:40:43 2025 daemon.warn openvpn(inst1)[5100]: WARNING: No server certificate verification method has been enabled. See Guide To Set Up & Configure OpenVPN Client/Server VPN | OpenVPN for more info.
2506 Thu Mar 20 23:40:43 2025 daemon.warn openvpn(inst1)[5100]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2507 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
2508 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
2509 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: TCP/UDP: Preserving recently used remote address: [AF_INET]:1194
2510 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: Socket Buffers: R=[180224->180224] S=[180224->180224]
2511 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: UDPv4 link local: (not bound)
2512 Thu Mar 20 23:40:43 2025 daemon.notice openvpn(inst1)[5100]: UDPv4 link remote: [AF_INET]:1194
2513 Thu Mar 20 23:41:43 2025 daemon.err openvpn(inst1)[5100]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2514 Thu Mar 20 23:41:43 2025 daemon.err openvpn(inst1)[5100]: TLS Error: TLS handshake failed
2515 Thu Mar 20 23:41:43 2025 daemon.notice openvpn(inst1)[5100]: TCP/UDP: Closing socket
2516 Thu Mar 20 23:41:43 2025 daemon.notice openvpn(inst1)[5100]: SIGUSR1[soft,tls-error] received, process restarting
2517 Thu Mar 20 23:41:43 2025 daemon.notice openvpn(inst1)[5100]: Restart pause, 300 second(s)
