Opening a Website upon Local Access Point Connection
I would like to know the steps or configurations required to ensure that a designated website opens automatically when a device connects to the configured local access point. Could you provide guidance or documentation on achieving this specific functionality?
Your support in this matter is highly appreciated, and I look forward to your prompt response.
Evgenij Dubrovski
based on your case, you can use the Hotspot feature that is available on the WebUI. If you have not found the service, you can install the service on the Packages page in the WebUI. However, before you configure the Hotspot configuration, please follow the steps below:
  1. Open the SSIDs page;
  2. Click the Edit button on the selected SSID that you will use as interface for Hotspot configuration;
  3. Select – No network – option on the Network field;
  4. Click Save & Apply button.
The following is an article you can use as a guide to configure Hotspot feature: RUT956 Hotspot - Teltonika Networks Wiki
Referring to the article above, specifically, you can use the Success page option to set specific pages to automatically open when a device is connected to the access point.
Thank you.
Alam N.
