I Want to Do that Open VPN Configuration In RUTX10 teltonika modem .For that requirement Text file Format & Guidance for Step by step procedure.
Thanks for reaching out!
We got really detailed description regarding the OpenVPN on our wiki page. You can reach from here.
We also have step by step configuration example, you can also reach from this link.
Caner
Sir please help me to how to genrate CA,server,& Client certificate to communication For Open VPN in Teltonika modem.
Also Provide me text File Format .Ovpn File to connect in Open VPN application to Connect File
You can create the certificates from the WebUI.
You need to go to the System > Administration > Certificates on the WebUI to generate the certificates. I also recommend you to check this link.
Caner
