OPC UA server on RUT901 missing settings
Have installed and enabled OPC UA server on a RUT901, but there are no settings found beyond Enabled, Port and Encryption.
I can connect, but the only nodes given are the one that describe the device. Thats fine, because:
By default, there are no nodes configured. To add a new server node, enter an instance name and click the ‘Add’ button.
(source)
But where does one add a new server node?
Springfeld
Hi springfeld,
Additional package should be installed. Under System → Package Manager → OPC Client. From here, you can configure new server node after adding a new instance.
Let me know if this helps.
