One WiFi antenna or two?
Hi all - I have a RUT X10/X11 setup where WiFi is only getting fed from the LAN - no repeating of outside WiFi networks. At the moment, I am only using a single WiFi antenna for each one. Question: is there any benefit in connecting a second antenna to each unit?
Yes, it is better to have two WiFi antennas attached as this will provide you with 2x2 MIMO. Hence, this can result in increased throughput, coverage, range, better signal quality, etc. If you are interested in learning more about 2x2 MIMO, I recommend reading some online articles about it.
