One WAN for VPN IPSec, one WAN for internet access
I have a IPSEC tunnel setup and established.
I need to configure one WAN/SIM for the IPSec VPN and another WAN for Internet access. What steps do I need to follow to set this up?
Could you please clarify your current setup and what you’re trying to achieve? Are you using one wired WAN connection and a SIM card for the second WAN? Also, what device are you using?
Do you want all tunnel traffic to exit through one WAN, and all other traffic to exit through the second WAN?
I’m using one wired WAN connection and a SIM card for the second WAN on RUT200.
I want all VPN traffic to exit through a SIM card, and all other traffic to exit through the wired WAN.
Best Regards
You should be able to use policy-based routing for this setup. You can find a configuration example here: Policy Based Routing - Teltonika Networks Wiki
If you encounter any issues during configuration, please share your network topology diagram (including IP addresses, but excluding any public IPs) along with screenshots of your current IPsec configuration (ensure no sensitive information is visible). Also, could you confirm whether you have a separate LAN configured for the IPsec tunnel?
