Offline datapoints timestamps different time zone
Hello forum,
Using FMC125’s I’ve noticed some of them record data points with time stamps of 3 hours less than actual time, when the tracker is in an area with no cellular signal. When the tracker has signal and uploads AVL packets directly, no such problem occurs. I’ve seen this on at least 3 x FMVC125’s now.
Is this a setting I’ve missed?
Hi Heinburgh,
Please try to adjust the settings of your device to after time-sync.
I also advise to use the latest firmware which is 03.29.00.rev.14 for FMC125: https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.14_and_configurator.zip
Regards
Maynard C
