Number of ssh connections to TSW202
Hello
How many ssh connections are possible to a TSW202 for cli commands at the same time?
I want to switch all 8 ports on or off, but I can only control 5 ports.
Thanks for some help.
By default, the device’s SSH configuration does not limit the number of SSH connections.
Thank you.
You are welcome.
Is there anything else you need assistance with?
I would like to know if I can get the Power consumption of a POE-Port over SSH or SNMP?
Can I toggle Ports on or off with snmp commands?
Thanks for help.
You can retrieve power consumption via SSH. I recommend checking this Tsw202 PoE power consumption via cli - #3 by Marijus for more details.
Regarding switching ports on and off via SNMP, unfortunately, this functionality is not currently available.
For more information on available SNMP variables for the TSW202, please refer to this link.
Let me know if you have any more questions.
Thank You very much.
You are welcome!
root@TSW202:~# ubus call tswconfig.poe get
Command failed: Not found
root@TSW202:~# ubus call tswconfig.poe get | jsonfilter -e ‘@.port7’
Failed to parse json data: unexpected end of data
root@TSW202:~#
The linked solution is not working. Does the code change for a TSW202?
Apologies for the delayed response and any confusion caused.
Instead of using ubus call, we recommend utilizing our API. You can find the relevant documentation here:
TSW202 API Documentation – Port Settings
Please don’t hesitate to reach out if you need any assistance with the API.
Thank you very much for that link. It looks as it, that what I want.
But I need some more help if I write in the CLI of the teltonika 202 switch: get/ports_settings/status
comes an error.
Can You please give me an example, what I must write in the CLI to use this code?
