Number lan ports different from 4 to 0 in RUT956
Hi
In teltonika RUT955 the number of lan ports is from 0 to 4. For example, if I want to check if LAN1 of teltonika is UP, I can use this script:
  • swconfig dev switch0 show | grep port:4
Now I see on RUT956 that the numbers of lan ports is from 4 to 0. So now if I want to check if LAN1 of Teltonika RUT956 is up, I have to use this code:
  • swconfig dev switch0 show | grep port:0
The number then of lan ports has been changed from 955 to 956?
Bye
Hello Tecfil
Welcome to the Teltonika Community :smiley:
Regarding your query, Yes, it has been reversed as per your finding, is it causing any issues in you’re use case
Please let us know
Thanks rashid for you reply! Perfect so I create a new service for new teltonika :slight_smile:
Have a nice day
