Ntpclient not working, Could not resole host
Hi
ntpclient is not working.
with the cli i try:
root@xxx:~# ntpclient -c 1 -h 0.openwrt.pool.ntp.org
Could not resolve 0.openwrt.pool.ntp.org
root@xxx:~# ping 0.openwrt.pool.ntp.org
PING 0.openwrt.pool.ntp.org (212.25.15.129): 56 data bytes
^C
--- 0.openwrt.pool.ntp.org ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
root@xxx:~#
or
root@xxx:~# ntpclient -c 1 -h 192.168.230.1
Could not resolve 192.168.230.1
root@xxx:~ping 192.168.230.1
PING 192.168.230.1 (192.168.230.1): 56 data bytes
64 bytes from 192.168.230.1: seq=0 ttl=64 time=17.866 ms
64 bytes from 192.168.230.1: seq=1 ttl=64 time=15.888 ms
64 bytes from 192.168.230.1: seq=2 ttl=64 time=17.378 ms
^C
--- 192.168.230.1 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 15.888/17.044/17.866 ms
root@xxx:~#
DNS is working, our local timeserver is reachable
So why ntpclient can not synch?
Version RUT955
Firmware version RUT9_R_00.07.05.4
Firmware build date 2023-11-07 18:33:51
Internal modem firmware version SLM750-V_4.57.20_EQ101
Welcome to Teltonika Networks Crowd Support!
Can you verify if you enabled NTP Client under System → Administration → Date and Time → NTP
Also, make sure to add your local timeserver hostname in Time Servers.
Let me know if this cleared your doubts.
Hello
The NTP settings are correct according to the pictures. Thanks
After a reboot the command worked:
This morning I wanted to test it again. Via Web CLI.
It promted ‘Could not resolve 0.openwrt.pool.ntp.org’ again
After logging in again via Web CLI (no reboot) it worked normally. Doesn’t seem to be constant.
Internet connection works. Because everything was tested via VPN tunnel.
Difficult to test the NTP settings and servers. If the time is currently correct. That’s why I thought via command ntpclient… is the best option.
