I’ve a problem where I currently completely stuck.
I have a Windows Server 2022 and want to use the NTP001 Stratum-1-NTP-Server as NTP-Time Server.
So far I’ve configured in gpedit the Time Provider accordingly as NTP client. My NTP001 has a fixed IP-Address and its time stamp is valid and the GPS signal is fine.
Nevertheless the Windows Server isn’t accepting from the NTP. Every time when I place the order “w32tm /resync” in the Command prompt I receive the same reply:
Sending resync command to local computer
The computer did not resync because no time data was available.
I tried already several times to start/stop the Timeserver and updated the policies as well.
By entering: w32tm /query /peers /verbose
I get:
#Peers: 1
Peer: 192.168.210.199,0x8
State: Active
Time Remaining: 41.6720853s
Mode: 3 (Client)
Stratum: 0 (unspecified)
PeerPoll Interval: 0 (unspecified)
HostPoll Interval: 6 (64s)
Last Successful Sync Time: (null)
LastSyncError: 0x800705B4 (This operation returned because the timeout period expired. )
LastSyncErrorMsgId: 0x00000000 (Succeeded)
AuthTypeMsgId: 0x0000005A (NoAuth )
Resolve Attempts: 0
ValidDataCounter: 1
Reachability: 2
By entering this: w32tm /query /status /verbose
I get:
Leap Indicator: 0(no warning)
Stratum: 1 (primary reference - syncd by radio clock)
Precision: -23 (119.209ns per tick)
Root Delay: 0.0000000s
Root Dispersion: 10.0000000s
ReferenceId: 0x4C4F434C (source name: “LOCL”)
Last Successful Sync Time: 17-09-2026 09:57:30
Source: Local CMOS Clock
Does anyone have a similar issue for configuration?
The error code LastSyncError: 0x800705B4 indicates a timeout—the Windows Server is sending NTP requests on UDP port 123, but it is not receiving a response back from the NTP001 (192.168.210.199).
First, could you please log in to the devices (NTP001) webUI and navigate to Time and verify that the Enable NTP server option is turned on? (By default it’s set to off)
Additionally, please ensure that both inbound and outbound UDP traffic on port 123 is allowed on the Windows Server 2022.
Please check the Windows Defender Firewall with Advanced Security settings and verify that there are appropriate inbound and outbound rules allowing UDP traffic on port 123.
Please note that the following PowerShell command:
tests TCP, not UDP, so it cannot be used to directly verify NTP connectivity. The firewall rules should therefore be checked separately to ensure that UDP port 123 is permitted.
We hope this helps. Please let us know if the issue persists after checking these settings.
Sorry for the late reply, but I was busy on other projects.
I’ve checked as you mentioned that NTP Server on the NTP001 is enabled → this is the case.
Second I’ve added a firewall rule for outbound connections and the UDP port 123. For Inbound it was already existing.
Unfortunatelly the time sync isn’t working at all. When I set the time manually to a difference of e.g. 10-15 min it stays there and never gets update to the same time that comes from the NTP001.
What else could be the cause?
The interesting thing is, that I’ve a default Operator station with Windows11. There it is wokring fine and perfectly. So it seems to be really a Windows2022 issue.
