no access to RUTx50 in bridge mode
I no longer have access to my RUTx50.
We were at the campsite, I wanted to fish WiFi. It didn’t work - so I activated BRIDGE mode in the Internet setting. Since then I no longer have access to the router.
Unfortunately, the router cannot be reset using the reset button or via SMS.
When connecting to the router wifi I get IP address 169.254.115.19 in the subnet 255.255.0.0
is there an emergency IP?
or how do I get access to the router again?
Thank you very much
Could you try setting a static IP on your WiFi interface to be in the RUTX50 LAN range? The default LAN is 192.168.1.0/24, so if this setting was not changed, you could set a static IP to 192.168.1.10 and netmask to 255.255.255.0.
When this is done, try reaching the WebUI of the RUTX50 by entering the IP 192.168.1.1 in the search bar on your browser of choice. If you are successful, revert the changes made previously.
If that does not help, could you try checking if the device is still reachable via RMS?
