Having an issue sending Modbus data collected over serial through data to server function utilizing MQTT. I have data coming into the device over the modbus serial connection verified utilizing the test interface on the UI. The MQTT data works when sending BASE data but not when utilizing modbus data.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18791.
