Network/firewall/forwards
I have a remote access problem with a RUT 241 in version RUT2M_R_00.07.12.3 and its LAN IP in 172.30.0.201 and mask 255.255.0.0.
The sim card has a dynamic public IP address.
A port redirection is set in Netowrk>firewall>Port Forwards from wan port 8080 to port 443 of an IP address (172.30.13.2).
By typing the public IP address followed by :8080 it is impossible to access the web page of 172.30.13.2. Knowing that I have exactly the same configuration on another site and that it works.
The goal after is to put a DDNS so that remote access is constant.
Thanks in advance
Thank you for reaching out and your inquiry. Could you please confirm if remote HTTP access is enabled? You can check it in System → Administration → Access Control page.
Additionally, I recommend reviewing our Port Forwarding for Accessing LAN Devices guide, which might provide helpful insights as well. You can find the guide here: Port Forward: Accessing LAN devices
Let me know if you need further assistance or have any additional questions.
