NAT on wifi client interface?
I have a machine with a RUTX11, using default IP range on LAN side, and having a SIM card.
This is working fine :wink:
To workaround regions with poor 4G coverage we instructed our field engineers to add wifi client on the router to connect to residential wifi network.
This is working fine with a mobile phone access point, but obviously quite badly with most of the residential wifi network, as most of them are also using 192.168.1.0/24 ip range.
My question is: is there a way to customise the router by adding nat or something similar in order to make it work ? (of course, without changing the lan ip range of our router and ask the customer to change his wifi settings.
many thanks for your ideas and help
