MWAN3 and xfrm (ipsec)
Hi. Using mwan3 and ipsec vpn at the same time is not working using RUTX_R_00.07.06.3. Seems like this is a known issue with OpenWRT: mwan3: incompatible with xfrm interfaces (used for ipsec) · Issue #19607 · openwrt/packages · GitHub
I was thinking about testing the fixes described here: mwan3: fix some tunnels assigned the wrong mark by anyuta1166 · Pull Request #20923 · openwrt/packages · GitHub, but I did not make it work.
Are there anyone who has made this work?
BR,
Havard
