Hi. I would like to have two remote users connect at he same time on VPN to devices under the same TRB Gateway. Is this possible? I have tried running the same OpenVPN profile from two different computers and it causes both to continually reconnect.
If you are using Static Key authentication, it is meant for P2P communication (1 Client ←→ 1 Server). More information can be found here:
If you are using TLS authentication with certificates, make sure you either generate two pairs of certificates (one for each client), or enable the Allow duplicate certificates option. If you are pushing routes from both clients, make sure their subnets do not overlap.
If these suggestions do not help, please replicate the issue, then navigate to System → Administration → Troubleshoot, open System logs, and copy the logs from the last few minutes. Make sure to censor any sensitive information like public IP addresses, etc. These logs can be pasted into the next comment, or if they exceed the character limit of the comment, upload them to a third-party file sharing service and share the URL. Thank you!
Best regrads,
