Using ubus / JSON-RPC, we would like to get the following information about the mobile radio :
RSSI
Connection type (LTE, 3G, 2G, …)
Connection status (data disconnected, connected)
SIM slot used
We are using RUTX09 modems.
“ubus call gsm.modem0 info” seems to give most of this information, but I couldn’t find any specs explaining the enumeration fields, like " network_state or net_mode
Could you give some specifications about this status message (or any other ubus message that would contain the mobile status) ?
For the connection status and SIM slot used, I cannot find certain ubus call commands for it. I tried the command below but it’s not working on my end.
ubus call gsm.modem0 get_sim_slot
Alternatively you can use
ubus -S call network.interface.mob1s1a1_4 status
SIM 1 - mob1s1a1_4
SIM 2 - mob1s2a1_4
If there’s an output on certain SIM interface, means it is the one which is active and connected, otherwise, it will output nothing.
