Monitor 4G connectivity on dual SIM
Currently testing a RUT901 with two simcards from different providers. It seems only one of them are connected to the network at a time - is that correct?
Is there a router model that supports both simcards to be connected at the same time and where you can see the connectivity status and signal strength on both the active sim and the failover sim?
Yes, you are correct. Only one SIM is active at the time. RUTX12 has two modems and it can create connection on both of them at the same time.
Thank you very much. I’ll look into the RUTX12 as well.
