modem data disconnected
hello teltonika I have rut device 955 doesnot connected on network on network status on connection read not registered
I have tried different troubleshoot procedure but fail to restore device like
rebootloader,reset to factory and modem updater
note it fail to attach troubleshoot file for new user
Hello teltonika why you are not reply this topic !what he important of this crowd support
Hi RUFAA,
  • tried SIM card in a mobile phone?
  • tried known working SIM in the router?
  • tried setting correct APN?
Timelapse Admin
Hello @RUFAA ,
It’s possible that the issue you’re experiencing could be related to the firmware version of your device. I recommend trying to install a different firmware version to see if that resolves the problem and rules out any potential hardware malfunctions.
Marijus
Hello teltonika
all possible check have been done correct but still the same problem modem disconnect
Hello teltonika
I have update firmware upto latest but still problem exist modem disconnect operator not registered
I try to change MNO simcard but still the same problem
If you’ve attempted all the steps you mentioned and none of them have resolved the issue, it appears that there may be a hardware problem. If your device is still under warranty, please reach out to your Teltonika reseller or contact Teltonika directly, especially if you made the purchase directly from us. We will then initiate the RMA process.
Marijus
Hello teltonika
Thanks for support
