Modbus TCP Server Table Missing IO PIN RUT956/TRb245
I am attempting to read the current Digital I/O (Input/Output) pin status from both the Teltonika RUT956 and TRB245 devices using the Modbus TCP Server service.
I have consulted the official documentation (including the wiki) but was unable to locate the equivalent Modbus register addresses for the digital I/O pins. Only registers for Analog Input were found.
I cant believe that a trivial feature —such as setting a dedicated Modbus register address for each digital I/O—would be unavailable on these devices.
Could someone please provide the updated Modbus TCP register map for the RUT956 and TRB245, specifically including the addresses for digital I/O status?
Another question is about the “data sources” from the same Service (modbus tcp client). I cant set any, cause isnt possible to set a “register source”. What could be happening?
Thx in advance!
We are currently working on your inquiry and will get back to you as soon as possible.
All register numbers can be found here:
A request to read the Digital Input (DIN1) state should look similar to the example shown here:
Could you please clarify what you’re trying to achieve with this register configuration?
