MODBUS TCP OVER SERIAL question
Hello
MODBUS TCP OVER SERIAL Can connect more than 1 slave id device?
i try to config 2 device but i can enable only 1 device
One Modbus TCP over Serial instance can be enabled on one interface at the same time, meaning (without using USB → Serial adapters) on RUT955/956 you can create two instances - one on RS485, and one on RS232.
