Dear all, I’m currently working with a Teltonika RUT360 router and trying to set up Modbus TCP communication. However, I can’t find the Modbus TCP option under the services menu.
Note: The router was previously used, but I have performed a full reset. I have prior experience with Teltonika routers (e.g., TRB140), and everything worked fine with those.
Do you have any idea what might be missing or what I should check?
On the RUT360 device, the Modbus service can be downloaded and installed via the WebUI by navigating to System → Package Manager.
