Mobile Module Fails to Detect Cellular Operators on RUT240
I have a new RUT240 router that came with a US power adapter. After going through all the setup wizards, everything seemed to configure correctly. However, the mobile module doesn’t detect any operators. When I insert the same SIM card into my phone, it works perfectly, but the Teltonika router can’t find any mobile networks.
Could you go to Status→System page and check Internal modem Model because it’s possible what modem only supports US bands (based on US power adapter you mentioned) and not EU/Asia.
From what country/region are you?
Or you can check by product code: https://www.teltonika-networks.com/products/routers/rut240
Hello @Sxiperio,
Could you please confirm if you still require any assistance?
Yes, as I mentioned during the hotline call, they said that once they find my message, they will get in touch and will need the troubleshooting file, which is private. So yes, it would be good to resolve this issue if possible.
Hello, Sxiperio,
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16183.
