I have a configuration where I would like to have both the WAN and Mobile connections working simultaneously.
Right now, I use a SIM cards where I can connect via an OpenVPN, which I would use for remote connection.
But at the same time, locally the router is connected to a certain network obtaining an IP address from the WAN interface.
My issue is that whenever the WAN is connected it has priority over the mobile connection and therefore I can no longer remote connect to the router.
Is there a way to have both working simultaneously? I tried to disable the failover rules, but seems to not help.
Thank you.
J.
